Push rod problem on SM engine
D.A.R.
02-26-2005 17:22:18
i overhauled a super m engine and we put it on the dyno today. it was running smooth until we started to put a load on it and it started backfiring into the intake. pulled the valve cover off and found the # 4 ex push rod came off the rocker arm and was bent. How could this have happened. the engine had a complete over haul and the head was rebuilt. any ideas?
K.B.-826
02-26-2005 21:05:23
 Re: Push rod problem on SM engine in reply to D.A.R., 02-26-2005 17:22:18
Bent pushrods are caused by valve-to- piston contact, or somthing between the valve and the piston. Possible the head gasket let a bunch of coolant dump into the combustion chamber, which then got compressed between the piston and the head, and held the valve closed. Another possibility is a broken camshaft. If just the very rear of it broke as it was pushing the #4 exhuast valve open, that would explain the bent pushrod, and the engine would still run on 3. Better pull the head.
Gordo
02-26-2005 18:10:31
Cart before the horse. The pushrod bent, THEN , as it was too short it came off the rocker. When your engine "backfired" it caused a tremendous overpressure in the cylinder that had the bent pushrod. I'd look for timing problem. ANd zero in on that cylinder. Double check rod installation. Valve length . That cylinder has major problem to bend the pushrod.
Gordo-SD
Gordo
02-26-2005 18:07:57
Gordo-SD
D.A.R.
02-26-2005 17:27:54
 Also water in oil in reply to D.A.R., 02-26-2005 17:22:18
I also notice that their was water in the oil. and when you shut it down you hear a bbbllluurrrppp in the head. didnt see any cracks when we rebuilt it. could it be the head gasket?
Novel Idea Guy
02-26-2005 20:11:52
 Re: Also water in oil in reply to D.A.R., 02-26-2005 17:27:54
Do you have a magnaflux machine for eyes or something? It's absolutely incredible that you can glance at a head with your natural eyesight and deem it good!
Seriously, you won't see most head cracks on a cursory visual inspection.
You've got some serious issues there... Better get out the wrench and start tearin' 'er down again...
