Tractor Vet/egr-IA, 1466 gear teeth in rear
SGT K
02-27-2005 03:55:59
Thanks for posting with ideas about where the gear teeth I found in the rear case came from. I have been through the transmission, the rear-end and the PTO. The only gear I could find that measured the same width as the gear teeth I found was the drive gear on the front power steering pump. I believe the pump had been replaced and the gear teeth left in the bottom of the transmission.
Even though I didn't find a broken gear I found plenty of other stuff to fix, which doesn't surprise me. This old girl was about wore out before I became the proud owner. Gotta love it.
Thanks for the help.
Paul
the tractor vet
02-27-2005 07:02:58
 Re: Tractor Vet/egr-IA, 1466 gear teeth in rear in reply to SGT K, 02-27-2005 03:55:59
Oh how well i know about finding what ya don't want to find , Like my personal 1486 the guy told me that all it needed was a new cablefor the T/A just got done disken 800 acres with her good tractor looked it over ran it around no this tractor has a nice cab and i did not here the engine misse or fell it , how could you the clutch sliped so bad that it bearley got on the trailer when i got it home that is when ya start finding all the neat stuff , did the clutch and T/A all gears in the speed trans all new bearings in trans ans rear end new cam shaft rebuilt the whole ft.end new a/c compressor new this new that and all the labor i would have to 35000 out of that one but they JUST GOT DONE DISKEN with it .
John Hobby
02-27-2005 04:43:19
Hey Sgt,
Sound like the saga continues. What did you do about the seal, sounds like you ripped it apart to get at the whole thing, huh ? Better hurry up, it is almost March, April is around the corner and you are going to need that bad boy. Good luck Sarge.
