Spin On Conversion
PAULIH300
02-27-2005 11:09:09
Since changing my 300U to a spin on oil filter (from CNH),there has been a constant oil seepage under the aluminum adapter cup.The tiny,flimsy rubber ring they use to seal that cup down to the former cartridge sealing surface is woefully insufficient.When I first saw it,and its lack of flexibility and teeny dimensions,I knew it would be a problem.CNH/C-IH needs to look into that and improve (possibly go to a silicone ring?)the product.It costs enough.
Ibby
02-28-2005 03:30:36
 Re: Spin On Conversion in reply to PAULIH300, 02-27-2005 11:09:09
Hi Paul!
I'm interested in why you changed to a spin on filter. Do you think it filters better than the cartridge type?
PAULIH300
02-28-2005 18:35:39
 Re: Spin On Conversion in reply to Ibby, 02-28-2005 03:30:36
Sure is a lot less messy to change,and if its easier to change,you're more likely to change it more often.Besides,I consider cartridge filters antiquated...even though Mercedes and VW still uses that system.
And,while I have converted to electronic ignition,modern spin on filtering seems a good companion move.Now if it could just have fuel injection.....
