International 300 330 350 Utility Steering
Ibby
02-28-2005 04:00:59
I've been watching the threads concerning the weaknesses in the steering of these tractors. I certainly can sympathize, having spent one hellacious gob of money buying a nearly new power steering assembly for my 350.
I sold the old unit to a friend that wanted to rebuild it for his 300 utility. He was able to replace most of the worn parts with ones from his old manual box and about $250 worth of seals and gaskets.
The interesting thing is - his old manual box was tight and just like new inside, even though it was older and the tractor beat up as bad as mine was. THe first big difference was in the previous owners maintenance. (He bought it from my uncle, so I've know and driven that tractor for a lot of years) My uncle changed all the fluids once a year, including the gear oil in the steering box.
The previous owner of my 350 only changed the engine oil once in a blue moon if he remembered. (The other fluids ran out almost as fast as they were poured in, so he assumed that topping them off was as good as a change.)
I think the REAL culprit in the steering problems is loader use. Mine had a worn out and beat to crap loader on it, his 300 didn't. I think loader use rips these up more than normal.
I've removed my loader and won't put it back on. I'm also keeping close track of the gear oil and other maintenance items, and we'll have to see how long it lasts.
I do wonder if a set of steering stabilizer shocks from a pickup would help smooth the sharp snaps that put a lot of stress on the steering boxes.
big fred
02-28-2005 08:53:43
 Re: International 300 330 350 Utility Steering in reply to Ibby, 02-28-2005 04:00:59
That's the main reason I ain't fixing the busted loader that came on my 300U.
Novel Idea Guy
02-28-2005 04:58:53
I agree with you wholeheartedly. Most so-called "defects" or "problem areas" on tractors are due to operator abuse.
You can run a loader on these tractors, but when you treat the loader like a battering ram, as many many many operators do, things break.
PAULIH300
02-28-2005 09:30:43
 Re: International 300 330 350 Utility Steering in reply to Novel Idea Guy, 02-28-2005 04:58:53
I blame the most of the wear on running fully loaded buckets and then trying to steer the wheel without any movement forward/backwards.I wait until the tractor is moving to steer.If only everybody before me did that....
