Questions on Farmall A Pistons
caveboy_98
02-28-2005 08:12:30
Hello
I have a quick question. Were high compression piston standard on a Farmall A made in 1945? I'm trying to figure out if the engine has been rebuilt and when I took the engine apart it had raised high compression pistons. I thought flat pistons were the standard. Any info would be appreicated.
thanks
derek
IH Red in LH
02-28-2005 10:56:55
 Re: Questions on Farmall A Pistons in reply to caveboy_98, 02-28-2005 08:12:30
I would say the pistons are replacements. They are for sure unless they are cast iron. In 1945 they would more likely be recessed pistons for kerosene unless they were to be used at high altitude. In any case they would be iron.
