Two Questions
'49 Farmall
02-28-2005 15:49:25
I have two questions with respect to the drawbar and cultivator assemblies for a Farmall Super AV. First off, will a standard farmall A or super A drawbar for an AV dimensionally? In other words, can I buy a straight A drawbar, and then have the drops and other high crop brackets made up to make it work instead of holding out for a complete high crop assembly (If you happen to know of a drawbar assembly for an AV let me know :) )? Second question, I have the mounts for the midmount cultivators for my super AV and the spring attachment to lift them from the touch control assembly. Will the toolbars from regular a/ Super A cultivators fit these mounts and does anybody know of anywhere that sells the toolbars separately with the shanks? I am located in Connecticut and will possibly drive 2-3 hours for the right equipment. I also need a complete set for the rear as well. Thank you for your help.
Tom
dave140
02-28-2005 18:44:04
 Re: Two Questions in reply to '49 Farmall, 02-28-2005 15:49:25
You might want to try a company called OEM Tractor Parts. They make Farmall and IH parts for tractor pre-1958. The have exactly what you are looking for right to original factory specs. Dave
Bryan Meade
02-28-2005 15:56:40
as for the draw bar, you can buy them from several places, probably even from here. but the after market replacement ones i have seen do have a drop to them but are basicly the same thing.
as for the tool bars, dont quote me on this, but it seems from pics i have seen that the bars from the front axle are the same, but the bars pointing down to the ground holding the culitvator shoes are longer. can someone back me up on this one,????
