Inside the Belly of the Whale or Farmall H
Tailhunter
03-01-2005 09:40:03
While inside the transmission/rearend of my H, I have noticed something. There is a chipped tooth on the First/Reverse sliding gear. One tooth has a part, maybe a 1/4 to 1/3 of the tooth, broken off. Is this the end of the world or can I button her back up and run her like she is? I really dread having to tear into it any further, just because I"m not 100% sure of myself. Thanks for the advice..... ....
Tailhunter
03-01-2005 13:34:07
 Re: Inside the Belly of the Whale or Farmall H in reply to Tailhunter, 03-01-2005 09:40:03
Thanks for all the help!!
Andy Martin
03-01-2005 12:50:05
NC is right. It probably happened one day when a previous owner was mad and jammed it into reverse.
If you have driven it and did not feel it clicking it is A-OK.
Don't back up to pull stumps.
riverbend
03-01-2005 11:04:47
Cowman is right. If the bearings and everything else is okay, I'd leave it alone. Be sure to check the mating gear for damage too. If you do decide to take it apart, there is no easier transmission to work on (once the cover is off).
Tailhunter
03-01-2005 13:33:00
 Re: Inside the Belly of the Whale or Farmall H in reply to riverbend, 03-01-2005 11:04:47
Just curious...What do you have to go through to change it out?
riverbend
03-01-2005 16:11:12
 Re: Inside the Belly of the Whale or Farmall H in reply to Tailhunter, 03-01-2005 13:33:00
The short form instructions are: 1)remove the hydraulic pump and clutch shaft 2) remove the front main shaft bearing retainer and the main drive gear 3) remove the rear main shaft bearing retainer and the main shaft .... The counter shaft is more of the same, then you can get the reverse idler shaft out. It is all pretty simple mechanical stuff, the pump is heavy.
With the parts in hand, it took less than a day to replace all the bearings in my gearbox. The IT manual was completely adequate to do the job. Doing it again, I would take the opportunity to check with Binder Books for a transmission manual (I already have a parts book).
Nebraska Cowman
03-01-2005 10:14:13
I wouldn't get my shorts in a wad. You will want to fish the broken pieces out of the bottom. Likely will run a long time.
