super av having flooding problems????
cajunace
03-01-2005 19:20:13
my old av is finally running. i have only one problem now. the carborator doesn"t stop the flow of fuel. i put a kit in it, i changed the flot after finding the old one to be full of fuel. when i kill the motor the bowl fills up faster than i can get around to see about it. so a second start after the first run of the day is impossible without first draining the bowl of excess fuel. any suggestions would help alot.
Farmall-Frenzy
03-01-2005 19:42:17
 Re: super av having flooding problems???? in reply to cajunace, 03-01-2005 19:20:13
Dan is right on the money, Your needle and seat is just as capable of flooding you out as the float is. I would check that first and if that doesn't work, Bend the ears slightly downward on the float to create a faster cut-off of fuel. I have had to do this on an M and a Super C over the years. Good Luck! Ed
Dan130
03-01-2005 19:29:39
Could be the needle and seat in your carb. Not sure if you change it or not, but one spec of rust or dirt in that seat will make it leak. Also, did you check the float to be sure it is adjusted right ? It's been a few years since I did the one on my 130, but there is an adjustment to it. Good Luck.
