H - Tank heater
MTK
03-02-2005 06:31:44
After using a magnetic block heater,and not being
impressed,I want to put on a (1000W) tank heater.
I am wondering what the best and simplest way to plumb it in would be ? Thanks for the help.
JOSSETTE
03-02-2005 16:30:03
 Re: H - Tank heater in reply to MTK, 03-02-2005 06:31:44
did that same thing to my 400 6 years ago. takes an hour to heat the head and it wont even take a half a crank and she's going. if there is a flow sticker on the heater--the flow should go out the block and then to the head...
Allan in NE
03-02-2005 07:02:47
MTK,
Dave's got it.
Just run the bottom hose of the heater from a nipple at the block drain and then the top hose of the heater back to a tee at that sender plug. She'll work just great.
Allan
third party image
third party image
Dave in CT
03-02-2005 06:49:16
I put one on my H at the beginning of this winter. I put a nipple in the block drain plug hole on the clutch side and a tee on the opening for the temp sender (brake side). Temp sender goes in one side of the tee. Ran the inlet hose from the drain opening and the outlet hose around the back of the engine, through a fabricated bracket to keep the hose away from the head, to the other side of the tee. Mounted the tank heater on a brace sticking up from the frame rail behind the carb. Works great.
