450 Hydrolic lever
Matt in MI
03-02-2005 07:07:29
On my 450 to outer most hydrolic lever is super sloppy. What may be causing this and how do I fix it? thanks
Novel Idea Guy
03-02-2005 09:20:12
 Re: 450 Hydrolic lever in reply to Matt in MI, 03-02-2005 07:07:29
The most likely cause? Worn linkages. It was probably the most-used, since it's the one that's traditionally plumbed to the rear of the tractor, or it's the one that runs the fast hitch.
The fix? Take it apart and rebuild the linkages.
Cory R.
03-02-2005 09:13:48
On my grandpas Farmall 300 Rowcrop the outermost lever is also sloppy there is a tiny pin inside that was wore we replaced that and it was stiff as the day it was made.
