super M pistons
m14dan
03-03-2005 06:08:35
I am restoring a super M I just came across. It got water in all the cylinders but luckily mo cracks to be found other than on the head, which I already repaired. Anyway, It"s LP powered. It has the high compression head, number 8060 if I remember correctly, and I am converting to gas. I want to put in a new firecrator set and am looking for suggestions or recommendations on doing it. Will they be good with this head is my first question? Also I know my super C had a different carb and distributer shaft from the factory for them. If the super M is the same way can anyone provide me the correct part numbers for them. I am thinking about buying the firecrator kit from webers but am waiting on a response from him. I was asking them if it is a complete conversion kit with the shaft and all. Thanks all, Dan
DWV
03-03-2005 19:10:27
 Re: super M pistons in reply to m14dan, 03-03-2005 06:08:35
Dan,the head is same casting as the gasoline so no problem there.Think you would be okay with SM carb as is.As for timing it would depend on what tractor is going to be used for.If for hard work
on regular gas I use dist shaft marked with # 22 on it and spring set # 362725 R91.Just my opinion though.
