Farmall 450 power steering
Bobcat
03-04-2005 08:12:12
I have a Farmall 450 that the power steering works well if the engine is running slow and works real well if the engine is running fast and one of the hydraulic levers is under a load. But, if the engine is running fast and the hydraulics are not used it hardly helps steer? Does anyone here have experiance and possibly a fix for this? I have replaced the screen in the sump and the fluid is new. And the hydraulic system works well on a loader and does"nt make any whining noises. Thanks Bobcat
the tractor vet
03-04-2005 08:27:52
 Re: Farmall 450 power steering in reply to Bobcat, 03-04-2005 08:12:12
It could be a sitcking flow divider or there is a plug between the mine valve body that could be working its way out , it's been awhile since i have been into one .
Bobcat
03-04-2005 16:11:25
 Re: Farmall 450 power steering in reply to the tractor vet, 03-04-2005 08:27:52
Thanks for your suggestion! I will clean it and see what happens!
Martin caldwell
03-05-2005 04:58:20
 Re: Farmall 450 power steering in reply to Bobcat, 03-04-2005 16:11:25
I have had the same problem. I piped in a flow divider valve into the system and now my power steering works. Once the flow divider on the tractor gets worn there isn't much you can do but pipe a flow divider into your system.
Bobcat
03-05-2005 17:45:31
 Re: Farmall 450 power steering in reply to Martin caldwell, 03-05-2005 04:58:20
Martin, If you could give me a E-Mail on how to do this I would sure be interested in trying this! E-Mail is open! Thanks!
