Pivot Bushings
PAULIH300
03-04-2005 12:20:32
Has anyone ever had to remove the greaseable pivot bushings for the lift arms on a U34 Power Loader? I've noticed that mine have developed some wear between the bushing and the loader frame bracket (the big hole).I want to eventually weld that area back up and grind it back to size,however removing those pivots could be a problem.
big fred
03-04-2005 12:50:15
 Re: Pivot Bushings in reply to PAULIH300, 03-04-2005 12:20:32
You mean the pins? Mine came out quite easily. Best I can recall I picked it up with a hoist, then gave 'em a whack with a 3-lb plastic dead-blow hammer. They're greased, so they don't get rusted in place. I could see where gettin' 'em back in might be a chore, though, and not a one-man job.
