pull behind brush hog.........
willy-g
03-04-2005 17:40:50
Looking for a brush hog that I can pull behind my F-12. Where can I find one? Who makes em?
Mac
03-05-2005 10:31:46
 Re: pull behind brush hog......... in reply to willy-g, 03-04-2005 17:40:50
I've got an old 2 wheel crank lift 5' Brillion for my SuperC. I think you'll have to find an antiqe like that. I've seen a few IH ones here in classifieds.The newer pull cutters I've seen require 3X the hp you have. I've also got an older (Servis not rhino) one of these that came out in the 50s I think. The SuperC can't do much but clip bahia grass heads with it.
El Toro
03-04-2005 18:16:17
Try this web site.
Link
or call 209-523-0781. Hal
willy-g
03-04-2005 18:28:04
 Re: pull behind brush hog......... in reply to El Toro, 03-04-2005 18:16:17
Ok, Which one will work on these farmalls that dont have a three point hitch?
El Toro
03-05-2005 03:58:10
 Re: pull behind brush hog......... in reply to willy-g, 03-04-2005 18:28:04
Send an email to info@bobequipment.com and ask what Bush Hog is available for your F12. Have you tried contacting a dealer in your area that sells these mowers? Your local IH dealer probably has these too. The Tractor Supply Co
may have them. The Northern Tool Co has mowers
and you can call them toll free at 1-800-533-5545.
Not having either the fasthitch or 3-point hookup
may be problem lifting this mower. There are some
rotary mowers that have an engine mounted on the mower and you just tow it with the tractor's drawbar. Hal
willy-g
03-05-2005 06:36:29
 Re: pull behind brush hog......... in reply to El Toro, 03-05-2005 03:58:10
I have a three point brush hog for the fords. I was wondering if one was made with 4-wheels for the farmalls. Ok ,thanks I"ll check around localy for one.
John M
03-05-2005 07:28:39
 Re: pull behind brush hog......... in reply to willy-g, 03-05-2005 06:36:29
You will need and adapter for the PTO.
farmallhal
03-05-2005 07:26:59
All the four wheel models I've seen here in Missouri are really finish mowers. They work great on lawn type grasses that aren't very tall but don't think they would handle normal field stuff. I've seen some older appearing brush hogs with a 2 wheel axle running about mid way between the front and back. I don't know if these are currently still being made or not. They should work fine with a drawbar Farmall tractor. I've seen new Bush Hog brand ones with a drawbar hitch and a manual leveling crank around this area as well.
