Carburetor float
Steven Donahue
03-05-2005 12:20:56
Hi
How does the Carburetor float shut of the fuel? I think the previous owner tried to fix the Carburetor and lost some parts.
Steven Donahue
03-07-2005 15:15:55
 Re: Carburetor float (THANKS FOR THE HELP) in reply to Steven Donahue, 03-05-2005 12:20:56
THANKS FOR THE HELP!!!
Joshua Smith
03-05-2005 16:22:14
 Re: Carburetor float in reply to Steven Donahue, 03-05-2005 12:20:56
Carb floats work like sump pumps. the float basically rises as the gas comes into the chamber. As it rises it pushes a little pin(close to the hinge) up into the hole where the gas comes in. The pin has a rubber tip which seals off the hole when the float rises far enough( the chamber is full). the bottom of the carb can be removed by four screws which gives you acsess to the float.
Sloroll
03-05-2005 12:40:15
A small needle valve rides on the arm of the float. As the float raises with gasoline in the bowl, the needle rides the arm up into the valve seat above it. As the needle is lifted into it's seat the fuel flow to the carborator is shut down.
BWatson
03-05-2005 16:23:53
 Re: Carburetor float in reply to Sloroll, 03-05-2005 12:40:15
If the guy was messing with the float height the needle may be in the bottom of the bowl, I've seen this happen a couple of times.
