IH 574 Steering Leak
TDK
03-05-2005 20:34:27
Leaking hyd. fluid around steering column. When tractor is cold it leaks very little or not at all. When tractor(hyd. oil) warms up leak is pretty bad. I am looking at parts manual, which seal or seals need to be replaced ? Appreciate any and all opinions.
Bernard le mécano
03-06-2005 21:27:29
 Re: IH 574 Steering Leak in reply to TDK, 03-05-2005 20:34:27
Hi TDK, on the 574 tractor, like 74 and 84,85,95 serie, it's a Danfoss steering valve. You have to remove all the valve from the tractor and open the valve to change the seal. Some part inside have to be timed, so if you don't have open a Danfoss valve before, good luck.Best way, keep the valve to a CaseIh dealer and ask to change the seal. To instal the seal, you need a special tool. Be careful when you remove the steering wheel, don't blow on the shaft with a hammer, remove the wheel with a puller. I have done many seal change when i have worked for CaseIh dealer. Bernard le mécano Québec Canada
the tractor vet
03-06-2005 08:19:28
Thats and easy fix , just get yourself a steering wheel puller and a 1/4 inch fine thread bottoming tap and clean the holes out and two long 1/4 fine bolts about 5 inches long remove nut pull wheel remove snap ring replace wheel on shaft give it a quick twist the seal will pop wright out and the seal pkg will cost ya around 10-12 bucks.
John inWV
03-06-2005 06:53:13
Order Seal Kit. Easy to install. Remove Hood,Battery,Batterytray,Steeringwheel.Replace upper seal in steering motor. Common oil leak.
Colorado Curt
03-05-2005 20:53:34
Email me and let me know the part number. I just took off a unit from a 544 that may work.
TDK
03-06-2005 11:27:39
 Re: IH 574 Steering Leak in reply to Colorado Curt, 03-05-2005 20:53:34
Thanks,guys ! I'm glad to hear that it's an easy fix. Tractor belongs to my neighbor, but I'll be fixing it for him. He'll be happy to have it fixed, starting to be a mess with fluid all over it.
