lift all will not hold up loader
minnesota super
03-06-2005 10:50:21
I have a supper M farmall with a farmhand loader and controled from the liftall bellypump. it all worked fine until i lifted a heavy bucket of snow and then the liftall will lift fine but it won"t hold the loader up it just lifts and then comes back down can anyone give me some suggestions i have the pump apart and the steal ball the one has bad groves worn into it is that the problem and can the seats where those balls sit go bad? thanks for all your help.
MagMan
03-06-2005 11:39:21
 Re: lift all will not hold up loader in reply to minnesota super m, 03-06-2005 10:50:21
Yes you can get those steel balls at the dealer but you probly shouls have the seat lapped also. I would think more along the lines of you picked up to much weight and blew out the seals in the loader cylenders. Happened to my H JON
minnesota super m
03-06-2005 18:57:36
 Re: lift all will not hold up loader in reply to MagMan, 03-06-2005 11:39:21
mag man can you tell me more about seat lapped and how i should do this or get this done and you think that i blew out the seals on the cylinders on the loader it self? and do you know where i can get new seals for the loader cylinders and is there seals in the belly pump or are the steel balls the only seals? thanks
Ronald
03-06-2005 19:07:25
 Re: lift all will not hold up loader in reply to minnesota super m, 03-06-2005 18:57:36
The only seal in the pump is on the drive shaft. If it leaked you would see it underneath the tractor, and this would affect lifting power not holding power. I can't imagine damaging the steel balls all at once, seems more logical problem is in one or both cylinders. Is there a return line going back into tractor from the cylinders? If not when the cylinders are damaged they will blow oil out the top when you raise them.
minnesota super m
03-09-2005 17:19:12
 Re: lift all will not hold up loader in reply to Ronald, 03-06-2005 19:07:25
yes one of the hydraulic cylinders leaks oil out the top but it only does it when you put it up as far as it will go and no more fluid is in the pump to push it up any farther, but it has done that for a couple of months
minnesota super m
03-06-2005 19:48:48
no there is no return line they are one way cylinders but they don't blow oil out the top only the one and thay was that way when the guy who owned it before me and that only leaks oil when you raise it up all the way. but i'am open for any suggestions. thanks
MagMan
03-07-2005 03:25:25
 Re: lift all will not hold up loader in reply to minnesota super m, 03-06-2005 19:48:48
I cant remember how I did it its been so long I found another steel ball I beleve that was a little bigger???? I think and used some valve grinding compound and a stick and epoxyied it to the ball and worked it around to clean the seat a machine shop could do it quick like they grind a valve seat. But Like the other said thats just the ball seats to hold back the hyd pressure. I had a loader and I rebuilt my pump about 6 different times I was so P#$% untill I took the cylenders off and took them to the local hydrolic shop and they found new neaprene seals for me and machined a few pucks to push on them right. Wow what a difference and I ended up with one heck of a pump to LOL. JON
minnesota super m
03-07-2005 19:58:13
 Re: lift all will not hold up loader in reply to MagMan, 03-07-2005 03:25:25
jon do you know anything about the thin tin gasket in the pump is that the only gasket that there is? and you had neaprene seals put in your hydraulic rams on the loader and what are pucks? and if so i wonder where i could get those seals? thanks justin
MagMan
03-08-2005 04:40:33
 Re: lift all will not hold up loader in reply to minnesota super m, 03-07-2005 19:58:13
Those are the shimms I beleve that shim the pump gears away from the body you would need a manual fro more info. You would have to do a search or look in the yellow pages for someone in youe area that does hydrolic repair work. Take them one of the cylenders or tare one down and take them the tube and seal and they should be able to help you. JON
Aces
03-06-2005 10:55:14
If the ball has grooves in it that should be the problem.
