1941 Farmall H
FMM
03-06-2005 18:09:48
Maybe a stupid question, but does a 1941 farmall H have a thermastat in it? The radiator cap is non pressurized. My H does not get above 120 or 130 unless you really work the pee out of her. If so does the radiator have to come out to get to it?
FMM
Paul in Mich
03-06-2005 18:39:37
 Re: 1941 Farmall H in reply to FMM, 03-06-2005 18:09:48
YOur 41 H should be configured for a thermostat. Whether or not it indeed has one is something else. you do not have to remove the radiator to get to it. The upper inlet mounted to the engine is made so that it can be split and the thermostat removed or installed. It also does not require removal from the engine itself.
