06's-56's-26's-66's-86's???????????
Dave From MN
03-07-2005 05:47:08
The more I look at to buy, the more I need some advice as to which "series" is the better . I have heard some were weak in the axles, some hard to start. I grew up on 06's and the neighbor had a 656 that would have some shifting issues. Beleive it was the linkage. Box of worms but are they all generally the same or are there strong good/bad points that I should know. Wife said keep it under $7000 and make it worth more. She likes the pretty Red ones that make that nice smell (Deisel)..... .. only from a farm chic that only had to wash milk buckets and feed calves.
JiminIA
03-07-2005 09:19:10
 Re: 06's-56's-26's-66's-86's??????????? in reply to Dave From MN, 03-07-2005 05:47:08
It all depends on how it was taken care of for starters. Are wanting a cab or no cab 86 definatly has the best cab. I have 656 that is always a hard starter, but a good running tractor. My 1066 always starts good has plenty of power and like said above is terrible on fuel,and the cab is terrible would be a real nice fender tractor though. Things to look at would be TA, front end should be tight, shift linkage should be tight..hope this helps..Jim
John Hobby
03-07-2005 12:35:30
 Re: 06's-56's-26's-66's-86's??????????? in reply to JiminIA, 03-07-2005 09:19:10
Jimmy, whats up ?
I got my 1066 Friday. She a goodin, you would like it. I still plan on getting to your dads farm on the manure spreader. Had a still born calf this morning, man, if that doesn't tick you off. 9 months and that happens. Felt sorry for her, she was looking after it like it was alive and when I took it to the woods, she was still looking. Sad. Sad I lost the cash too.
Gordo
03-07-2005 09:02:35
My preference is the 966 Black stripe, deisel of course. Mine starts in 1-2 turns at below freezing temps NOT plugged in. But I do plug it in if I have plans to start it. It's miserly on fuel, power to spare, and I got it and a DUAL loader, 4000 hours, for under 7K. 4 years ago..
Gordo-SD
Hugh MacKay
03-07-2005 06:49:42
Dave: I farmed with some of these tractors, but in my day they were still relartively new, thus many of the problems we now see croping up hadn't yet happened in my day.
Reading this forum for the past 5 years, I would have to say 06 and 56 have been by far the best tractors. I think there are a number of factors for this. Number one in my mind, most 06 and 56 series tractors were paid for by the time the mid 80s down turn in the ag economy. They were owned largley by farmers in much better shape financially to with stand the down turn, thus these tractors received much better service. I firmly believe that is number one. From a power train point of view all that changed significantly were the engines.
The shifting linkages were adequate for a tractor doing field work with drawbar and 3 point. The ones to go first were loader or other jobs that required a lot of shifting. There have been good repair and rebuild kits for these and are money well spent for a work tractor.
On the other end of the scale you have 66 and 86 series tractors, many still not paid for when the downturn hit. Many of these tractor worked far beyond their service intervales. Even the guys that survived with these had to cut corners. That is not to say there are not good 66 and 86 series around in good condition. Heck there is a 1086 in the photo adds right now (MI) less than 400 hours since new, that would be a gem to get your hands on.
Best rule of thumb buying these tractors be vigilant, anyone of engine, TA, transmission or hydraulics, will make buying a shift linkage seem like peanuts.
Butch WI
03-07-2005 06:36:22
Dave,
I too, grew up on an 856. Around the farm it was known as "the Iron Horse" Did very little work to it only a clutch and a TA. Now has Round 8000hrs still purrs!! Hard to start in WI winters but not a problem when you plugged it in. I hope it gets to be mine some day! Dad still has it, retired from farming though!
Butch
RustyFarmall
03-07-2005 06:02:20
Dave, I owned an 856 diesel, the only thing I didn't like about it was that whenever the temperature dropped to 40 degrees the tractor would not start without being plugged in for at least one hour. I think I read somewhere that the IH boys came up with a cure for that by increasing the compression of the engine? I had no other problems with the tractor, and it had lead somewhat of a rough life before I became the owner.
