Farmall 706 transmission problem
scott farmall
03-07-2005 09:01:37
hi, im looking at a 706, the owner says the transmission makes a loud noise sometimes. Usually after you stop and "lock" the transmission, then when you "unlock" the transmission to take off it sometimes makes the noise. im wondering if this is a sounds like a serious problem? Thanks
scott farmall
03-07-2005 12:35:02
 Re: Farmall 706 transmission problem in reply to scott farmall, 03-07-2005 09:01:37
To: the tractor vet, Thanks for the info! If its out of adjustment, is it hard to adjust?
the tractor vet
03-07-2005 15:22:24
 Re: Farmall 706 transmission problem in reply to scott farmall, 03-07-2005 12:35:02
No not realy just get yourself a I T manual and fallow the steps , but like i said if i owned it it would get the spring loaded on.I realy hate chasen a tractor down as it is going down hill with out you.
the tractor vet
03-07-2005 09:23:04
It could be , At one time someone could have dropped the park lock while still moving and this will chip a toothe or it could be a chipped rev. Or it could be that the park lock is not comming all the way up because it is out of adjustment . If it is only out of adjustment and no damage then i would replace the old style park lock with the new spring loaded one and it is avaibale at Case I H .
