300U steering problems
old
03-07-2005 12:35:45
The steering is very hard, found water in the steering box and would like to drain it and change the fluid but I can't find any place to drain it and the I,T, manual is of no help. By the way its manual steering. Where is the drain plug???
Thanks
PAULIH300
03-07-2005 17:37:44
 Re: 300U steering problems in reply to old, 03-07-2005 12:35:45
I dont believe there is one.I guess you just were supposed to keep it full and thats it.If it leaked out thru the pitman shafts or the welsh plug on the bottom,then you had the automatic drain!
I'm not looking forward to when I remove and dismantle my worn box....its been packed full of chassis grease thru a grease fitting on top.I cant wait to see the damage....woooooppppie!
