El Toro, Magman, CNKS !!READ!!
Joe Farmallman
03-07-2005 16:21:00
I got My Farmall to runnin today. Of everything it was the spark plugs. I guess i had just fouled them out to many times. Thanks. (She fired right off with new ones)
El Toro
03-07-2005 17:29:10
 Re: El Toro, Magman, CNKS !!READ!! in reply to Joe Farmallman, 03-07-2005 16:21:00
Glad you got it started. If you had hook a sparkplug to the sparkplug wire and grounded the plug against the engine. You would see the plug
wasn't firing even though you had fire from the plug wire. Now you can reset those valves. Hal
MAGMAN
03-07-2005 16:48:32
Good For You! Thats why you always check the little things first. I tore my first harley down for rebuilding when it started to run on 1 cyl. Thought I blew it up or something I took it to my mechanic and he Agreed with me and said I dont see where anything is wrong. Honed it put new rings in and put it back together. A few days later it did the same thing come to find out one of the push rod lock nuts came loose and the adjuster turned and opened one of the valves. And thats why I lost a cylinder. All that work and money for a simple fix that I should have checked first. But thats how we learn I guess. JON
El Toro
03-08-2005 08:24:59
 Re: El Toro, Magman, CNKS !!READ!! in reply to MAGMAN, 03-07-2005 16:48:32
Hi Jon, Did Tanner ever get his tractor started?
He may have had the same problem as Joe Farmallman
did. I haven't seen any postings this year. It's snowing like crazy here in MD today. It was 70 degrees yesterday. Hal
MagMan
03-08-2005 09:21:26
 Re: El Toro, Magman, CNKS !!READ!! in reply to El Toro, 03-08-2005 08:24:59
You Know Hal I dont really know what happened to Tanner. He said he had some thins going on for the next few weeks or month and thats the last I ever heard. Someone put a post a week or two back for him I dont think he ever answered. Same here yesterday I dont know how warm in NY but I will say 60 then the wind blew the s%$%6 Flew and its 16 degrees F here today. And Gordo Sends those darn plowing Pics It really SU%^ ya know. I was thinking yesterday That we should have a spring retreat for us guys in the NE To get together and shoot the bull and such. Heck maybe some plowing contests in the snow. LOL The weather man says we are in for a snow storm in the next few days and bad weather for the 7 day forcast. I need to find a winter Hobby I guess I am going Crazy. HAVE A GOOD ONE JON
El Toro
03-08-2005 10:46:18
 Re: El Toro, Magman, CNKS !!READ!! in reply to MagMan, 03-08-2005 09:21:26
Hi Jon, Speaking of the devil, Tanner posted
today, but nothing about the tractor. Hal
dr.sportster
03-07-2005 19:36:35
Dont feel bad I locked up a rear wheel trucked the bike home, took off the top end only to later find it had picked up a red mechanics rag stuck up into the sprocket and chain uner the sprocket cover where I didnt see it at first.
Joe Farmallman
03-07-2005 17:57:09
I want to thank you all for your time and ideas. I have already reset the valves. Runs pretty good. Need to clean sediment bowl, and tweak with the carb a little. i think i got it leaned a little much. Thanx again for the help. LATER
El Toro
03-08-2005 08:34:50
 Re: El Toro, Magman, CNKS !!READ!! in reply to Joe Farmallman, 03-07-2005 17:57:09
Hi Joe, We even screw up every now and then and think the worse. Somtimes it's a minor problem.
You should change the oil and filter in that old tractor and grease the steering. Those front wheel bearings need to be cleaned and repacked with new wheel bearing grease. Have fun at the FFA parade. Hal
