TA Elimanator Kit?
Dann
03-08-2005 04:25:05
Saw a TA eliminator on e-bay for a 460 any body ever install one ? Showed a friend the picture of it he said it was not all there and was missing a front carrier? He also said it was to much money and I would loose my live power Any anwsers to these questions/ Thanks
chadd
03-08-2005 09:08:45
 Re: TA Elimanator Kit? in reply to Dann, 03-08-2005 04:25:05
I have heard of TA eliminator kits, but have never installed one myself. As for the losing live PTO, I don"t think that is correct because the power for the pto is driven by a shaft inside of a hollowed out transmission shaft. This inside shaft is driven by the constant mesh gear if memory serves me correctly. Therefore, removing the TA shouldn"t effect it. As for the money, I don"t know how much it costs. Why not just leave the TA in the setting that works instead of removing it? Or else rebuild the TA even though it isn"t necessarily cheap. It seems like a waste of money to me to spend money to remove one of the nice features of the tractor. Or is there something very seriously wrong with the TA that you can"t understand how or afford to fix?
Allan in NE
03-08-2005 09:30:44
 Re: TA Elimanator Kit? in reply to chadd, 03-08-2005 09:08:45
Chadd,
I think you have it backwards.
The PTO shaft is hollow and hooks directly to the main clutch pressure plate. Tranny input shaft lives inside of the PTO shaft and hooks to the driven clutch plate.
Allan
chadd
03-08-2005 12:18:14
 Re: TA Elimanator Kit? in reply to Allan in NE, 03-08-2005 09:30:44
Yeah, I think that you are right, good catch. That"s it, I am just going to have to stop giving advice without looking at the books first! I couldn"t quite remember how that worked, seeing as I haven"t worked on a tractor that used it and only saw the diagram in the service manual. Thanks for your help.
captaink
03-08-2005 08:57:36
Dann,
Just curious as to why you are looking at eliminating the TA on your 460.
Kelly C
03-08-2005 08:21:23
I dont really understand this. To install the elimenator you have to do all the work you need to do to repair the TA. Might as well just repair the TA. If it is slipping on the low side. New rollers just cost 12 bucks. Seal kit cost about $60 but you need that any way.
Maybe if the planitary set is bad might save some money but only for that.
Allan in NE
03-08-2005 09:06:46
 Re: TA Elimanator Kit? in reply to Kelly C, 03-08-2005 08:21:23
Hi Kelly,
I agree, plus the fact that by eleminating the T/A, you've lost half the tractor.
Just doesn't make any sense to me.
Allan
Pete1468
03-08-2005 05:29:29
I just put one in a 350 farmall, it's just about the same amount of time to install as a ta but you shouldn't have to ever do it again. Your live power will still be there, that has nothing to do with your ta, it's up in the flywheel pressure plate. If I remember correctly all you really need is a gear and a carrier.
Allan in NE
03-08-2005 04:37:04
Mornin' Dan,
Boy, I'm not so sure about those eliminator kits. Seems like it would just be a heck of a lot easier to trade down to an H?
I dunno,
Allan
steveormary
03-08-2005 10:15:49
 Re: TA Elimanator Kit? in reply to Allan in NE, 03-08-2005 04:37:04
If"n you dont have the TA you dont have the tractor.
The TA makes the tractor.
