Farmall A oil filter conversion
joelmetal
03-08-2005 06:22:30
I have made a Spin-on oil filter adapter for my farmall A but am concerned about the amount of oil I allow to pass through the filter since it by-passes the bearings and just returns to the crankcase. The original is restricted with a tiny passage hole abount 1/16". Too large would reduce the oil pressure for the oil going to the bearings... any suggestions or sources for this information?
bermuda ken
03-08-2005 10:22:28
 Re: Farmall A oil filter conversion...........a so in reply to joelmetal, 03-08-2005 06:22:30
Why not just buy the conversion kit ( part # 538828R91..base & 538836R1...filter) from IH?? It has the proper flow rate that has been tested by IH Engineering (the same folks that designed the tractor)so you know it will work right.....
joelmetal
03-08-2005 14:35:52
 Re: Farmall A oil filter conversion...........a so in reply to bermuda ken, 03-08-2005 10:22:28
for bermudaken... Reference 'Just buy one...', I am retired, have a metal lathe, mill, etc. and love playing on them. So I make stuff. I have set the bypass bleed hole to 40 thousands over the stock, It seems to be holding the same pressure now. Oh yeh, I have lots of scrap steel and aluminum so the cost was zero plus 3.45 for a spin-on filter.
Thanks for you comments.
