Matt - Assuming decent roadway surface - i.e no potholes, loose rock, etc - a Super M will pull a 3,500 trailer up a reasonable incline with no problem. By “reasonable” I mean 15% - 20% maximum. (Drawbar pull at 20% would be around 700 lb – within the capability of a Super M without lifting the front end.) But a couple hundred lb of aux weight fastened to the front end would insure the front end stays down and aid steering. Another alternative would be to fabricate a hitch for the front end, then BACK the tractor up the incline with the boat hitched to the front end. However not only must you be able to climb the hill, you must be able descend it under control! The Super M’s disk brakes can be very effective, IF they are in good shape and IF they are properly adjusted. But if SM brakes have any problems they may not work at all. Also if only one side is working, stomping on the good brake can cause the front of the tractor to slew violently to the side and possibly roll - especially if you’ve got a load pushing from behind. Also....the brakes must be able to hold the tractor securely should you ever have to stop on the incline. (Think of the consequences were you unable to hold it from rolling backward with a boat attached.) Bottom line is a Super M should do the job. But you must keep the brakes in top condition. Always go slow and exercise caution. Finally keep in mind anytime you operate a tractor on an incline it's a dangerous activity. Don't become a statistic!!
