400 OR 450 Farmall
Diggerstoy
03-08-2005 13:31:45
I need some help in identifying this tractor.The only numbers visible are 7427 s . I am not sure what to think. I was told at time of purchase that this is a 450 Farmall.I was also informed that a 45o has a 281 c.i. engine. This paticular tractor has a 264 ci.I did find out that the 400 were made between 1954-1956, and used the 264 c.i.. and the 450 was built between 1956-1958, and used the 281 c.i. engine. If it is a 400,it would be a 1955.If it is a 450, it would be a 1957.Can someone help me clarify this . I do enjoy pulling this tractor in Antique pulls.My curiosity is up. Thanks
JOSSETTE
03-08-2005 16:42:20
 Re: 400 OR 450 Farmall in reply to Diggerstoy, 03-08-2005 13:31:45
down by the oil filter is the moter size nimber.
above the hydro pump is the month -day and year of the motor. the year will be a letter.
mine says c-264-----11-7-Z
should be a casting number on the left side by your feet( front of the battery box...10-7-Z
Z == 1954
