farmall 706 310d miss
Trent R. Young
03-08-2005 17:01:21
I had an injector line leaking comp. fitting broke and had a miss and white smoke would not clear up would this be because of the miss?? no real good on diesels any help would be great thanks
Aces
03-08-2005 18:00:17
 Re: farmall 706 310d miss in reply to Trent R. Young, 03-08-2005 17:01:21
Trent if a line is leaking yes that will make it miss. When you replace the line make SURE you get the right line or it will stil miss. Don't know about the D310 and the D358. But the 806 D 361 had different lines than the 1206 D361 and would not interchange with out a miss. Can change all but not one.
