Order Farmall Cub Parts Online
Hydraulic Parts for Cub
Neil Rissler
03-08-2005 19:39:45
Where is the best source of parts for the Tough Control unit on a Farmall Cub?
Slappy
03-09-2005 03:20:12
 Re: Hydraulic Parts for Cub in reply to Neil Rissler, 03-08-2005 19:39:45
Your IH/CNH dealer has rebuild kits available. Apparently there were at least two different models, so have part numbers off your unit available when you order. I've never done it, but I'm told it is a relatively straight forward job to rebuild these units.
Redned@optonline.net
03-09-2005 15:31:52
 Re: Hydraulic Parts for Cub in reply to Slappy, 03-09-2005 03:20:12
Slappy's right.Your Case/IH dealer will have all the parts for your Touch control.Just get the No# off the Block.It would be very wise to change the screen filter.After 50 years you can bet it's shot.A little pricey$ though.Pretty easy to do just keep everything clean.
