M pops out of 5th gear
Mark Welte
03-09-2005 09:57:43
I have a '49 M and every time I put it in 5th gear it pops out when you let out on the clutch. all other gears work as they should. Does anyone know what is wrong or how to fix it.
Thanks
farmall teen
03-13-2005 08:22:44
 Re: M pops out of 5th gear in reply to Mark Welte, 03-09-2005 09:57:43
Put it in 5 gear and when you let out on the cluch,hold the stick in place. Might stay in gear.
captaink
03-10-2005 08:49:15
It could be any of the things below. If you take of the belt pulley (or blank cover if you don’t have a belt pulley) you will be able to look into the transmission and check some of the things others have mentioned.
BRD
03-09-2005 14:17:05
Most likely the 4-5 slider gear and input shaft are worn allowing the slider to slide back out of gear. This is more common with h's than m's
Sloroll
03-09-2005 10:52:18
I had a similar problem with an H. It turned out to me the high end bearing. It is located high and to the front of the transmition. Easy to change but you will have to drop the hydrolic pump if it is your problem.
Scott Swanson
03-09-2005 10:14:43
Could be the little ball detents that hold in springs to keep the shifter forks in place. If the 5th gear gets a little worn, a sloppy ball detent may not be able to keep the fork in place. 5th speed gears may be worn as well. Good Luck!
bermuda ken
03-09-2005 10:07:56
You probably have a bent shifting fork.....
