steel wheels
young
03-09-2005 17:01:59
any difference between steel wheels on f20 and regular ? thanks !
Mike Androvich
03-10-2005 14:43:57
 Re: steel wheels in reply to young, 03-09-2005 17:01:59
In my recollection there are 5 different variations of front steel wheels for the Farmall Regular (not counting the Fairway type or wide front end style). The early wheels were flat roller bearing type with the later ones being roller bearings. The correct wheels are dependent upon the year of the tractor. As for the rears, the Cowman is right they will all interchange, but the early rears were a cast hub rather than the stamped type found on all F-20s. There were many variations depending on geography and owner preference. The F-20s basically has one style of front steel (again not counting Fairway or wide fronts, and the rears were multiple types.
John M
03-10-2005 04:20:11
Do you need some?
young
03-10-2005 18:48:20
 Re: steel wheels in reply to John M, 03-10-2005 04:20:11
yes i am in the market for regular steel wheels if reasonable.if i can not find reg ill settle for f20s. thanks for all the help !
Harold H
03-09-2005 18:18:45
For any given year there were many rear steel wheel options. My 1935 catalog shows pictures of eleven different rear steel wheels for F20 and lists even more options and variations of these.
Harold H
Sloroll
03-09-2005 17:16:18
THey will fit each other. It depends on if you want to stay year correct. Late Reg and early F-20 are the same, I believe.
Nebraska Cowman
03-09-2005 17:14:59
No difference
Bob from IL
03-09-2005 18:25:41
 Re: steel wheels in reply to Nebraska Cowman, 03-09-2005 17:14:59
Question? I always thought the rears didnt make much difference but what about the fronts cast centers vs the stamped.
Nebraska Cowman
03-10-2005 03:29:11
 Re: steel wheels in reply to Bob from IL, 03-09-2005 18:25:41
there are several variations but they all interchange.
