Hydraulic on M farmall
JRV
03-10-2005 17:35:37
What is the capacity, in quarts is the hydaulic system of a "52 farmall M . My friend has added a 3 point hitch to his tractor . Also what is the best type of oil to use. Thanks
T.B.W.
03-10-2005 17:47:07
 Re: Hydraulic on M farmall in reply to JRV, 03-10-2005 17:35:37
The belly pump holds 6 qts of 30w non detergent oil. That is enough to run a 3 point. if you add a loader, you need to add a qt.
Nebraska Cowman
03-10-2005 17:43:51
7 quarts off the top of my head but you can overfill them if you need to to get the cylinder to work.
Nebraska Cowman
03-10-2005 17:44:23
Nebraska Cowman
03-10-2005 17:42:19
EricB
03-11-2005 08:34:27
 Re: Hydraulic on M farmall in reply to Nebraska Cowman, 03-10-2005 17:42:19
Ok Cowman! Your head is off! Stop repeating yourself
