H4 Continental Magneto, can it be switch for H use
Scott Swanson
03-11-2005 09:14:34
I have an angled magneto I bought at a swap meet years ago. I got it home and realized the mounting plate was angled. Somebody told me it is for a Continental engine. Can it be used on a regular Farmall H or am I going to have to sell it or trade it for a usable H4 Mag. It has a wild blue mega-spark. Any ideas out there?
Thanks,
Scott
gene b
03-11-2005 18:14:16
 Re: H4 Continental Magneto, can it be switch for H in reply to Scott Swanson, 03-11-2005 09:14:34
It is from the CONTINETAL engine used on the pulltype combines. It could be used on the H but you will need to change the timing of the mag drive gear so it would fire at TDC. I have played with one on a block and it could work ok if you change the gear mesh on the mag gear so that it fires on TDC If i remember moving three teeth will do it.
Redmud
03-11-2005 15:46:08
What about swapping out the base from the H mag?
Jim Becker
03-11-2005 16:04:20
 Re: H4 Continental Magneto, can it be switch for H in reply to Redmud, 03-11-2005 15:46:08
That should work and would be necessary to get the timing right. From the other comments here, looks like the impulse coupling from an H-4 tractor mag should be swapped on too.
Red Dave
03-11-2005 10:37:28
I know what you mean, I have one too.
Mine was used on the power unit of a combine. (Model 61 or 62, I think)
The difference is the spark retard. I think a standard H4 on a tractor retards 35 deg, and the one I have is only something like 15 deg. Not 100% sure of the numbers, I have the details at home, not here.
Paul in Mich
03-11-2005 09:37:29
Scott, Are you referring to a right angle distributor? If so, this was an aftermarket distributor and fit all the letter series tracvtors. You will need a coil to go with it. I don"t know of a angled magneto, but that doesnt mean there wasn"t one, just an extreem rarity.
MagMan
03-11-2005 11:08:04
 Re: H4 Continental Magneto, can it be switch for H in reply to Paul in Mich, 03-11-2005 09:37:29
Yes scott thats right. I have rebuilt a few of them they have a much slower lag angle than the regular H4. I how ever have never tryed one on an H and always wondered if it would work my self. You may not be able to time it right. They were used on bailers ,Combines and continental motors. If you have a chance to try it on an H let us know how you make out so I will know in the future. JON
Scott Swanson
03-11-2005 09:41:52
It is an H4 Magneto. It is the exact same as the Mag on My Farmall H. It does, however, have an angle mounting base. The base on the H mag is vertical, straight up and down. The base on the goofy mag is angle about 30 degrees or so. Somebody said it was from a flat-top engine.
Spark is blue as the sky and grabs you quick.
