Anybody Remember?
Allan in NE
03-11-2005 14:24:04
Hi,
Anybody remember what year the antifreeze filter update came out? I'm thinkin' 1980, but sure can't say for sure.
Allan
caseyc
03-12-2005 09:49:29
 Re: Anybody Remember? in reply to Allan in NE, 03-11-2005 14:24:04
allen,
my neighbors bought their 966 new in early '75 and it had the water filter from the factory. how much earlier than that i don't know, but it was atleast by '75.
casey in SD
Gordo
03-11-2005 18:18:38
MY 75 966 HAS FACTORY filter.
GordoSD
Allan in NE
03-11-2005 20:00:59
 Re: Anybody Remember? in reply to Gordo, 03-11-2005 18:18:38
Gordo,
Did you buy that tractor new?
Allan
Chuck's Repair
03-11-2005 18:15:52
I remember putting them on in the early 1970's.There was a service bulletin on that subject.They were for all 300 and 400 series engines with the wet sleeves.
Farmallkid From Ont,
03-11-2005 15:31:56
Was that for the 1066? To help slow down the cavitation probablem?
Now i got a ? fer ya. Was it just the 10's that had the cavitation, or was it the 7's 9's 14's and 15's to? I have only ever heard of the 10's having that probablem. Someday i want a 1066, they look sweet, and the #1066 just screams power to me!!!!! !!!
Allan in NE
03-11-2005 15:55:47
 Re: Anybody Remember? in reply to Farmallkid From Ont,, 03-11-2005 15:31:56
It was for all diesels as I remmeber. When my 966 was in the shop, they put one on, anyway.
Allan
JJK
03-11-2005 19:02:05
 Re: Anybody Remember? in reply to Allan in NE, 03-11-2005 15:55:47
Putting a water filter on any wet sleeve engine is a nessecity. All it is, is a pellet form of DCA, and it main purpose is to prevent electrolosis and it also prevents rust, scale, and any other corrosion. If you're not familiar with electrolosis, what happens is little air bubbles form on the sleeve and with heat and vibration they pop and with enough force eat away the metal working its way to the crankcase. With the rust prevention I tend to believe that it would be good to add a bottle of DCA to any cooling system(wet, dry, or no sleeve engines). There are test strips available to test the anti-freeze to see if it needs to be pre-charged or just a filter changed.
Allan in NE
03-12-2005 04:54:18
 Re: Anybody Remember? in reply to JJK, 03-11-2005 19:02:05
Thanks JJK,
Yes, I know that. Was just wondering when IH introduced the "fix". Had to be the very late '70s or 1980?
Allan
JJK
03-12-2005 06:53:54
 Re: Anybody Remember? in reply to Allan in NE, 03-12-2005 04:54:18
Thought it would be a good idea to explain it incase somebody reading all this that didn't know could learn something new.
