Rear end fluid for farmall 140-?
Big Red1
03-11-2005 15:52:22
any ideas what I should use to change the rear end fluid in a 140 recently acquired also how much should I add
thanks
Hugh MacKay
03-11-2005 16:13:57
 Re: Rear end fluid for farmall 140-? in reply to Big Red1, 03-11-2005 15:52:22
Red: Manual calls for 5 quarts, personally I'd go with 6 quarts. Gear oil 90W is what is called for.
Dion
03-12-2005 13:11:44
 Re: Rear end fluid for farmall 140-? in reply to Hugh MacKay, 03-11-2005 16:13:57
Does the rear end fluid also supply the final drives for each wheel? If not, what fluid for them?
Thanks
Hugh MacKay
03-12-2005 14:42:00
 Re: Rear end fluid for farmall 140-? in reply to Dion, 03-12-2005 13:11:44
Dion: No the final drives are separate compartments. The fill holes and these are also the fill to level holes are on the inner side on the front of each final drive, about an 1-1/2" plug removed by a 1/2" drive socket handle. Use the same 90W gear oil for these. They each hold about 3 pints.
Dion
03-12-2005 14:48:46
 Re: Rear end fluid for farmall 140-? in reply to Hugh MacKay, 03-12-2005 14:42:00
Hugh, Thank you for the info. I learn something new every day.
