IH 6 cyl bore
ChadS
03-12-2005 08:08:56
Has anyone bored out a IH 6 cyl bigger than 3-13/16? Im working on my 460 puller, and looking at running a 3.937 bore, does anyone know if the block can go that big, and still run on the block without adding sleeves? I know, I know, pulling board,,,, LOL but there is a few pullers over on this board too! any info would be great! Thanks! ChadS
ejr-IA.
03-12-2005 12:31:38
 Re: IH 6 cyl bore in reply to ChadS, 03-12-2005 08:08:56
560 crank bore the block too 60 over the stock 301 bore size will give you a 310cid.Bore would be 3.8725 x 4.390625 = 4 25/64 560 crank stroke.I see 60over 301 pistons for 275.00.
Harold H
03-12-2005 09:14:03
It is up to 301 cu in from IH in some applications.
Harold H
ChadS
03-12-2005 08:10:03
Also, the engine block is a sleeveless combine block (C263) if that helps. ChadS
