farmall m head.bushing for temp sending unit
tim bynum
03-12-2005 18:23:16
i have broken off the adapter for the temp. gage that goes into the head.can anyone tell me if it is threaded into the head or pressed.also where can a guy pick on up at.what is the best way to get the broken one out. thanks in advance. tim
Tailhunter
03-12-2005 20:03:06
 Re: farmall m head.bushing for temp sending unit in reply to tim bynum, 03-12-2005 18:23:16
I did the same thing...some good heat from a propane torch and an easy out...it had me worried there for a minute.
JOSSETTE
03-12-2005 18:55:34
jayw is right
now would be a good time to put in a tank heater
jayw
03-12-2005 18:43:49
Tim
It is just a bushing reducer that you can pick up at any hardware or auto parts House some are brass and some are BlackIron I broke one off myself and used a easy out to remove,Mine was 1/2 inch to 3/8 reducer
Bob
03-12-2005 19:51:36
 Re: farmall m head.bushing for temp sending unit in reply to jayw, 03-12-2005 18:43:49
It IS NOT just a "bushing reducer that you can pick up from a harware store".
It is similar to a pipe reducer bushing, in that the OD is threaded pipe thread, but the inside is threaded with a finer thread than pipe thread, and it has a "step" inside, beyond the threads, that the sender bulb bottoms against.
It should be no problem for a CNH dealer to get a replacement.
jayw
03-13-2005 06:17:52
 Re: farmall m head.bushing for temp sending unit in reply to Bob, 03-12-2005 19:51:36
The fitting that you are talking about was allready made on the Temp gauge that I bought,Mine also has the standard mpt bushing.
This may not be original but both my IH have the same type.
Bartt
03-13-2005 02:51:55
Exactly right Bob. Been there, done that. I did put a tank heater in while I was at it. Works slick as a trout.
Farmall Frank
03-13-2005 09:29:00
 Re: farmall m head.bushing for temp sending unit in reply to Bartt, 03-13-2005 02:51:55
What tank heater? Where do you get them? Don"t know anything about them, but my interest is up.
