M Drawbar pivot pin bolt broke off!!!!
Farmallkid From
03-13-2005 12:55:25
Was taking the draw bar off my M, I was takin the bolt out that keeps the pin in. It was nice and rusty, I was turning it and it broke inside. Now, how do i get the broke piece of bolt out of the hole??? Thanks.
NDS
03-13-2005 16:20:26
 Re: M Drawbar pivot pin bolt broke off!!!! in reply to Farmallkid From Ont,, 03-13-2005 12:55:25
If bolt is broken off flush and if you are handy with welder hold washer over bolt and weld then hold nut on washer and weld have seen many gotten out this way with very few failures. The heat will usually loosen it up and they will come right out.
Nebraska Cowman
03-13-2005 14:14:33
oops... you will have to drill it out. Not much fun but you are learning.
sammy the RED
03-13-2005 13:28:47
E-Z out.
skycarp
03-13-2005 20:54:01
 Re: M Drawbar pivot pin bolt broke off!!!! in reply to sammy the RED, 03-13-2005 13:28:47
One thing I learned recently on using easyouts, use the right size for that size of bolt. If you only have a few and use one that is too small, the chances are good that you will break the easyout off in the hole.
RustyFarmall
03-13-2005 22:05:56
 Re: M Drawbar pivot pin bolt broke off!!!! in reply to skycarp, 03-13-2005 20:54:01
The best thing I have learned about using easy-outs is DON'T. I gave all of mine away to less than favorite friends.
Easy
03-13-2005 23:38:59
 Re: M Drawbar pivot pin bolt broke off!!!! in reply to RustyFarmall, 03-13-2005 22:05:56
I have used them with good results. You need the right size, and drill the right size hole to make it work. I have seen guys make a version out of tool steel - usually good for only one use too. Easy.
