Farmall M hand clutch, lube question
Dick Davis
03-14-2005 04:50:52
No response to this post last time - maybe the subject was wrong? Surely somebody knows the answer!
Mr. Knauff of PA posted his M&W manual on Vintage Ads (Thanks You Mr. Knauff) In the lubrication instructions it talks about using the grease supplied by M&W and inserting the "Tip". Did this grease come in a tube? It also talks about inserting the grease fitting(supplied by M&W.) I assume this isn't a standard zert? Any information about this lubrication would be appreciated? How do you lube yours? Also I can't get the Vintage Ads to print without all the YT boiler plate. Dick Davis
DWV
03-14-2005 08:54:43
 Re: Farmall M hand clutch, lube question in reply to Dick Davis, 03-14-2005 04:50:52
Mine has a 1/8 pipe thread that takes a flat screwdriver to remove.I screw in zerk fitting and use wheel bearing grease.
knauffj
03-14-2005 06:36:52
I used high temp grease and just used a normal grease zert. I can't remember what size though?? Something common 1/4",1/8" ?? I could try to email the manual to you if you'd like. Would it work to copy and paste to a program like Word? I'm not too sure how to get it to print just the manual.
Dick Davis
03-14-2005 17:30:06
 Re: Farmall M hand clutch, lube question in reply to knauffj, 03-14-2005 06:36:52
I tried to copy it to Word and then print - didn't work. I'm about as dumb with computers as I am with Hand Clutches, thansk for the response. Dick Davis
