Super C axel question
Andrew Z
03-14-2005 04:52:18
I got a Super C in last week or so. I the process of changing the front main seal. And I was looking it over and I have a few questions, I have one axel longer than the other. The short axel does not apper to be cut or anything. the long axel is 6 or 7 inches longer. Also there is some type of wire comming out of the touch control is this some type of plug?? The wire is only about 3 inches long.
Thanks for the help Andrew
Stan(VA).
03-14-2005 05:11:45
 Re: Super C axel question in reply to Andrew Z , 03-14-2005 04:52:18
There were optional axle width's available. Someone probably busted an axle and just replaced it with a longer/shorter one from a salvage yard. The wire out of the touch control could be the temperature sender lead that should go to the gauge on the steering colum support.
Stan(VA).
