IH 350, how much should I bid?
Chris Hanson
03-14-2005 09:39:12
Hi everyone,
Well, I did buy my 560 wide front gas. Despite many people calling it junk, I got a good deal for $2,000. I will use it only to move bales and plow the driveway in the winter. However, I'm going to an auction with a good 350 and I am looking for a restoration project. It is a widefront with a 2-point. Assuming everything is good, how much should I bid?
Thanks,
Chris
Ksfarmmer
03-14-2005 17:22:44
 Re: IH 350, how much should I bid? in reply to Chris Hanson, 03-14-2005 09:39:12
I'm a little more familiar with the 300, but as I understand they are basically the same tractor. There is certainly a difference between the utility and the farmall. Saw a 300 utility go for $2500 with the engine and rear end both locked up. The same weekend a running Farmall sold for $300. Paid $1000 for my 300 with a narrow front end. I would guess a Farmall with a wide front end would be $1500 to 2000 and the utility maybe $2000 to 3000. All depends on the condition and obviously who else might also want to bid on it.
PAULIH300
03-14-2005 14:19:42
An IH350 is a utility not a Farmall.
Make sure you check that steering box!
Geoff NY
03-14-2005 15:22:18
 Re: IH 350, how much should I bid? in reply to PAULIH300, 03-14-2005 14:19:42
An IHC 350 could be a Farmall, but a Farmall can"t be a utility or Industrial or Standard. Remember IHC was the company, so they"re all IHC.
sammy the RED
03-14-2005 10:31:40
$2250.00
dhermesc
03-14-2005 11:32:19
 Re: IH 350, how much should I bid? in reply to sammy the RED, 03-14-2005 10:31:40
Sammy's number is a good "max" amount. The wide front is worth $300-$500 easily if its a Swartz. The IH wide fronts are worth even more to some collectors. If the TA works and it's otherwise complete expect $1500 - $2200. The 350 sips on fuel compared to 560. With live hydraulics and live PTO they are so much easier to use then an "H".
the tractor vet
03-14-2005 09:47:40
Well that all depends on what ya want to give for it . The auctioneer will tell ya when you have paid enough . Is it a fartory wide ft. or after market ?? . Ya got a deal on the 560 in my book and since i have not seen it it would be a good one to fix up and make it new again and would last ya a long time.
JOSSETTE
03-14-2005 09:46:36
I always add a zero to the number on the side of the hood and go up or down from there. the fast hitch is worth 400 easy- make sure it all runs and works and if there are any leaks take a little off and bid what you feel is a good price( whats in your wallet)___
