C and Super C Parts Interchangable?
skycarp
03-14-2005 20:32:05
I have a Super C that I will start to recondition soon. I have a chance to pick up a C out of a graveyard of dust and weeds at little or no cost to me other than transportation.
Will some/any parts interchange between these tractors?
Thanks in advance.
Haas
03-15-2005 06:14:45
 Re: C and Super C Parts Interchangable? in reply to skycarp, 03-14-2005 20:32:05
Some parts will some won't. Engines are different. C-113 in C vs. C-123 in Super. Most but not all parts interchange in engine. No water pump on C. Brakes are different. Pedals for clutch and brake are different. Others mention grill, and also radiator on Super is taller. So it depends on what parts you need for your super and what's the price.
Ernie Bob
03-14-2005 22:20:36
Some other things that are different are the brakes. The Super's had disc brakes and the clutch and brake pedals angle back toward the operator.
Donnie T
03-15-2005 06:07:09
 Re: C and Super C Parts Interchangable? in reply to Ernie Bob, 03-14-2005 22:20:36
Didn't all C and Super C have disc brakes? I'm pretty sure they did.
MN Scott
03-15-2005 07:20:27
 Re: C and Super C Parts Interchangable? in reply to Donnie T, 03-15-2005 06:07:09
The super C had the disk brakes and the C had band type brakes.
Donnie T
03-14-2005 21:00:47
About all the parts will interchange. Except for the grills. The super C has a spacer under fuel tank that raises the tank and hood. This making the C grill to short to work. The rest of the tractor is basicly the same.
David B
03-14-2005 20:58:10
Yep, they will interchange. I belive the Super C had a bigger engine than the C, and the radiator/grill was bigger. I think that's the only difference between the C and Super C, except age.
