flat belt pulley
Dan Zimmerman
03-15-2005 01:09:24
I am looking for a belt pulley for my 1942 Farmall M and wondering which would have been factory. A paper or steel one?
Also, did the factory hood decals have IH in front of Farmall?
Thanks
Dan
williamf
03-15-2005 11:02:01
 Re: flat belt pulley in reply to Dan Zimmerman, 03-15-2005 01:09:24
I would have one on my H, but I'm a dunderhead and don't. The previous owner showed me the paper pulley when I first went to look at the tractor. Then, next trip, after we loaded it up he said,"Oh yeah, the belt pulley is back at the barn. I'll go get it."
Yours truely, letting excitement&impatience get over sense, says, "Don't bother, I won't be needing it."
I 'magine he's long since ebayed it, but if I could remember his name I'd call and ask.
Wm, the dunce
MagMan
03-15-2005 07:01:30
Hey Dan I have a stock paper unit from a 41 M in NY. If your close to this area. JON
Dan Zimmerman
03-15-2005 10:47:45
 Re: flat belt pulley in reply to MagMan, 03-15-2005 07:01:30
Thanks for the help.
I think I will go with a metal pulley because I haven't seen too many at the shows.
Paul in Mich
03-15-2005 04:54:47
Dan, Both steel and paper pulleys were available, however most farmers prefered the paper pulley as when dressed it held the belt better than steel, which in turn caused the belt to track better. The hood decals on your 42 H would have had FARMALL and directly above had McCormick Deering. The IH logo didnt appear until after the war, which would have been 1945 and later. At that time the Deering name was removed also and only McCormick appeared over the FARMALL name.
RickL
03-15-2005 04:37:59
Dan Zimmerman; I have a belt pulley for M and H wanting to get rid of both good usable units
Nebraska Cowman
03-15-2005 03:33:36
The pulleys were optional. Most dealers ordered Paper because they hold the belt much better. In 1942 the decal read McCormick Deering Farmall, The later IH decals came in 1945. Maple Hunter has the correct ones.
Hugh MacKay
03-15-2005 04:30:53
 Re: flat belt pulley in reply to Nebraska Cowman, 03-15-2005 03:33:36
Cowman: I presume you are suggesting Farmall on the Farmalls and McCormick Deering on the W series tractors. You are right, I stand corrected.
The reason I hesitated on steel pulley back in early 40s, is my dad bought the W4 new with paper pulley. In 51 he traded the W4 for a new H. At delivery of new H with steel pulley by IH dealer my dad said, " hold on now quite so fast, I had a paper pulley and will continue to have a paper pulley." So the pullies go switched right there in barn yard. I expect you may find a few early 40s tractors equiped with steel pullies that happened just that way.
Nebraska Cowman
03-15-2005 04:41:23
 Re: flat belt pulley in reply to Hugh MacKay, 03-15-2005 04:30:53
No, you were not wrong Hugh. I think the question was about the decal on the side of the hood. I am sure the decal on the W series changed too but not too familier with them. this is row crop country.
Missouri Boy
03-15-2005 02:57:03
I never saw a steel belt pulley on an IHC tractor. All I saw were either cast iron or paper. Many smaller AC tractors had steel and I had a CA with aluminum.
Hugh MacKay
03-15-2005 02:48:51
Dan: I expect either pulley would have been available. I know paper was as my dad bought a new W4 in 42 with paper pulley.
On the front emblem above the grill, all plain letter series had the word Farmall or in the case of W series International. The IH emblem came with Super Letter series tractors.
