Super C Battery Cables
SuperCmore
03-15-2005 06:06:21
Anyone know how long the battery cables are for a Super C. I know the positive is short, about 6 or 8 inches, but how long is the one that goes to the starter? I also know I need "O" gauge or "1" gauge. thanks, Cmore
farmallhal
03-15-2005 07:52:22
 Re: Super C Battery Cables in reply to SuperCmore, 03-15-2005 06:06:21
Maybe I'm missing something, but I think all you need to do is figure out how you want to route them and measure that distance with a piece of rope and tape measure. Try and keep them as short as possible but still out of the way of moving items and away from sharp edges. Use size 1 cable or larger with soldered terminals.
JBlavl
03-15-2005 09:39:34
 Re: Super C Battery Cables in reply to farmallhal, 03-15-2005 07:52:22
The larger Dia cable you can get away with the better. It doesn't hurt to go big in this case but you'll regret going too small.
El Toro
03-15-2005 07:46:44
You can make up your own battery cables from heavy welding cables. You can custom fit them for length and solder spades on them with a propane torch. Hal
Cmore
03-15-2005 10:35:42
 Re: Super C Battery Cables in reply to El Toro, 03-15-2005 07:46:44
Just went to my friendly Case IH dealer. The positive is 5 inches and the negative, to starter is 24 inches. Had them made up using "1' gauge for $20.24! Cmore
El Toro
03-15-2005 10:55:24
 Re: Super C Battery Cables in reply to Cmore, 03-15-2005 10:35:42
Glad you got them. Hal
