M H Rear end Fluid, How much????
Farmallkid From
03-15-2005 08:54:08
Have to put new oil in the rear ends. How much do we need? Would three 5 gallon pails do? What do you usually put in? 8090? Thanks.
Michael Soldan
03-15-2005 15:53:52
 Re: M H Rear end Fluid, How much???? in reply to Farmallkid From Ont,, 03-15-2005 08:54:08
Hey Kid, go to Walymart...5 gallons of 80/90 is around $27.97. I put 6 gallons in the H's,more is overfilling. Same with the M, put in 11 gallons. Btw the hay mow is totally empty now and your threshing machine can be viewed from all angles, won't be long 'till you can get it out...Mike in Exeter Ontario
03-15-2005 16:36:51
 Re: M H Rear end Fluid, How much???? in reply to Michael Soldan, 03-15-2005 15:53:52
Still lookin for a spot around here to put it. If i can't find a spot here then i geuss it will have to go up to wyoming in my grandma's shed. Got a couple people who said they would truck it though!!!
Bob M
03-15-2005 09:21:56
An M takes 13 gallons to refill; an H about 7-1/2.
80W90 is fine.
RustyFarmall
03-15-2005 09:27:24
 Re: M H Rear end Fluid, How much???? in reply to Bob M, 03-15-2005 09:21:56
Bob, the book for my M says 11 gallon, but 13 1/2 is more like it. The H manual says 6, but 7 to 7 1/2 is closer.
Dave_Id
03-15-2005 09:10:16
Yes
Dave_Id
03-15-2005 09:10:14
Yes
