Water Pump: Stripped Packing Nut
PurdueAg
03-15-2005 10:09:12
Started working on the water pump assembly. Discovered that the packing nut was loose. Upon closer examination, I discovered that not only is all the packing gone, but the packing nut is stripped bare and has rattled around in there for God knows how long (how could somebody have run that poor old gal like that for what must have been quite a long time? The thing must have leaked like a seive!).
So, has anybody ever encountered this before? Can a new packing nut be acquired / manufactured? The threads on the housing (where the packing nut inserts) are a little worn, but not gone, I think they could be cleaned up. I checked with the IH dealer and a remanufactured water pump is $466.00. I hadn't asked yet whether I could just get the packing nut. Anybody know?
Thanks,
Tony
Haas
03-15-2005 16:26:42
 Re: Water Pump: Stripped Packing Nut in reply to PurdueAg, 03-15-2005 10:09:12
I assume you are talking about and M or H. If so, I'm pretty sure you can buy just the packing nut the IH dealer you talked to should be able to get it or try Carter&Gruenwald.
John M
03-15-2005 12:49:14
Whats it on, Imay have a extra laying around/
PurdueAg
03-15-2005 13:18:45
 It's on a 1942 H (nfm) in reply to John M, 03-15-2005 12:49:14
nm
PurdueAg
03-15-2005 13:17:55
 It's on a 1942 (nfm) in reply to John M, 03-15-2005 12:49:14
nm
captaink
03-15-2005 12:42:37
A new nut could probably be made by a machinist if he had access to the proper material. I would suggest trying a salvage yard to see if you can find a pump that has a good one on it. Depending on what else you need to get your pump in useable shape, it might be the quickest/easiest place to look.
PurdueAg
03-15-2005 13:21:09
 Re: Water Pump: Stripped Packing Nut in reply to captaink, 03-15-2005 12:42:37
Thanks for the advice. What about the pumps sold on this site? I saw they had a new (?) water pump for H's running at $129.00. That's a far cry better than the $466.00 for the remanufactured one at the Case-IH dealer. I can actually afford $129.00. Anybody ever buy one off this site?
Tony
CNKS
03-15-2005 17:58:45
 Re: Water Pump: Stripped Packing Nut in reply to PurdueAg, 03-15-2005 13:21:09
Not from this site, but I bought one from Steel Wheel Ranch -- made in China, or Taiwan, etc. Probably the same company. Replaced it because I couldn't the old one to stop leaking (used new IH packing). Can't get the new one to stop either. I think the Chinese one is metric, as to shaft size, etc. If you do buy it, put new packing in it, or it won't just drip, it will leak like a sieve.
