Help with Farmall ser. #
JDH
03-16-2005 04:17:41
I found a thought to be 300 Farmall, but I can"t find a ser. # in any list. I just wanted to confirm it is a 300 and what year. Ser # on the bell housing plate is 28904 APJ Any idea what it may be worth? It is complete and loose, but not running. Sheet metal is straight. Thanks, David
Paul in Mich
03-16-2005 05:55:47
 Re: Help with Farmall ser. # in reply to JDH, 03-16-2005 04:17:41
JDH, YOu can follow the menu on the left of the page under Research & Info, to verify your serial number. APJ wopuld suggest it to be distilate or kerosene, with Rockford clutch and Independent PTO. I would assume with this configuration, you have no TA.
