Farmall A Super C oil filter question.
Andrew Z
03-16-2005 06:07:44
Are the filters between my 45 A and 53 SC interchangable? What filter should I be useing in these tractors. I been useing WIX but have heard that they lead to lower oil pressure. And was wondering what is the number for a Fram or Purolator filter? are these better filters to use?? Thanks Andrew
Paul in Mich
03-16-2005 07:19:35
 Re: Farmall A Super C oil filter question. in reply to Andrew Z , 03-16-2005 06:07:44
Andrew, The filters are interchangable only if the cannisters are the same height. If your 45 A has the taller cannister, it takes a different filter. Wix is a good choice if you dont use genuine IH replacement filters. I won"t comment on Fram.
Randy in NE
03-16-2005 06:56:37
According to the parts CD they are totally different. The A is 63858D and the the Super C is 355009R91.
Andrew Z
03-16-2005 07:07:16
 Re: Farmall A Super C oil filter question. in reply to Randy in NE, 03-16-2005 06:56:37
Randy, My fault in last post cant type?!!
What are those numbers for, what type of filter does that go with? thanks Andrew
Andrew Z
03-16-2005 07:05:15
Randy, What type of oil filter are those oil filters for? Andrew
