Value of 656 Gas
RETCOL
03-16-2005 10:22:33
What is the value of a IH 656 gas, wide front, located in central Wisconsin? The tractor was overhauled about two years ago. The rear tires are good but the fronts are poor. The paint is faded but not bad. The tractor has a three point hitch. The TA is good.
wolfmantractor
03-16-2005 17:28:03
 Re: Value of 656 Gas in reply to RETCOL, 03-16-2005 10:22:33
Around here a good 656 gas with factory 3-pt, wide front & good TA,etc have held their value and/or gained in value steadily over the years. Going rate for a good one $5500- $5700. They happen to be a handy gaser that are kind of easy on gas since they only rev 1800 rpm. Nebraska test on them back then had a 656 gas yielding about the same hp/hours per gallon as a 3020 Diesel. Gas engine (263) although more modern than an M (264) about same cu in. A lot more smooth hp from less gas than an M.
GP
03-16-2005 12:24:27
$5500 to $6500. 656 and similar gas tractors are popular chore tractors for WI winters.
Allan in NE
03-16-2005 11:59:38
Ret,
If it comes at you like this old sister does, I'd give 'im just about anything he asks.
But, as you probably already know, I'm wayyyyy , wayyyyy biased towards those old 656s.
If only it was a diesel. :>(
With a new motor and good rock-solid T/A, it oughta be worth $5K, hadn't it?
Allan
third party image
pcy-1066
03-16-2005 15:16:37
 Re: Value of 656 Gas in reply to Allan in NE, 03-16-2005 11:59:38
they wont do that here in ohio i have a 656 dsl for 325o nf factory no ta cant get a offer
666 dsl wide front nice strait tractor 3 point for 4500 havent had a call listed it in the traden post had it on clasifieds here
686 312 dsl cab strait as they come 5500 966 factory nf ih cab dbl remote 6500
1066 72 model 1670 actual hrs 6000bucks nobody seems interested or act like there to high
