Ok...Here is one for you guys
FC
03-17-2005 07:10:49
I thought about putting this in the post below about the easy-outs, but thought I had better post a new thread for maximum exposure. I have a broken drain plug I need to remove in the belly of my C transmission. I started out innocently enough with a portion of the plug broken out, but thought I could get a good enough bite to remove (1/2 inch square drive inserted into the plug). I soon had about 2/3rds of the plug broken and now there is literally nothing left of the plug to get hold of. Tried a chisel on it thinking I could get a good enough bite to back it out, and just broke more off. Any ideas on getting the remains out so I can change the over 50 year old oil, and replace the broken drain plug? Note: I do not have a stick welder available, so all bets on using a welder are off. Should I try to drill, or break the rest out of the trans housing, or is the risk too great of damaging the housing beyond repair? All suggestions appreciated.
farmall puller
03-17-2005 10:20:08
 Re: Ok...Here is one for you guys in reply to FC, 03-17-2005 07:10:49
before Idid a lot of extra work I would get a left handed drill bit and try it. It might get a bite while drilling and spin it out
scotty
03-17-2005 07:26:01
Oh yea, you might get your angle grinder out and get that surface flat first and then pilot drill with a 1/8" drill first.
scotty
FC
03-17-2005 07:37:21
 Re: Ok...Here is one for you guys in reply to scotty, 03-17-2005 07:26:01
great idea idea scotty....I thought of drilling the hole, but for some reason the left hand tap, and bolt never crossed my mind. I knew I would get a workable solution here. I knew I had better add that I did not have a stick welder as I knew that would be one of the first suggestions. (I do want to acquire one someday though) I am going to print your response for my shopping list at Napa. Guess I had better find a plug as well....anyone know the size and thread of plug that will work in there? Would a standard size pipe plug work?
scotty
03-17-2005 07:52:56
 Re: Ok...Here is one for you guys in reply to FC, 03-17-2005 07:37:21
FC, Im thinkin 1/2 npt makin the plug something greater than 3/4" but Im not sure!
scotty
scotty
03-17-2005 07:20:51
FC, I believe that plug is cast iron. Drill a 21/64 hole through the bottom, let oil drain out, that will take awhile on small hole like that.While your waiting for the oil to drain, go down to your local NAPA dealer and buy a 3/8-24 thd left hand tap and tap the hole. While your at NAPA get a 3/8 24 LH hex head bolt. I will let you figure out the rest.
scotty
dr.sportster
03-17-2005 08:03:39
 Re: Ok...Here is one for you guys in reply to scotty, 03-17-2005 07:20:51
Yes Scotty Ill remember this one the left hand tap takes the left hand drill bit idea further and It is a drainplug so its not rusted in.Im making a mental note to keep that size on hand for future use.
