Angle Frame vs Box Frame Disk Harrows
Ramon from NC
03-18-2005 12:37:59
What is the general consensus out there are regards which is better, Angle Frame Disk Harrows or Box Frame disk harrows. I have very old set of angle frames but at some point, I'll be replacing it and I am wondering which is better. Also, do most folks think the sealed bearings are better than the cast iron bearings with grease fittings Thanks Ramon
Harold H
03-18-2005 14:05:51
 Re: Angle Frame vs Box Frame Disk Harrows in reply to Ramon from NC, 03-18-2005 12:37:59
We always had excellent service and life from the bolted angle iron type, such as; 37/370, 48/480, and 500 disks vs the competative welded disks of simular size and weight. On smaller and three point hitch disks the welded style probably gives equal service to the bolted style. On modern disks sealed bearings or regresable sealed bearings give better life than old cast iron or wooden bearings. IMHO.
Harold H
RAW in IA
03-18-2005 16:27:01
 Re: Angle Frame vs Box Frame Disk Harrows in reply to Harold H, 03-18-2005 14:05:51
The sealed or greasable bearing discs pull easier than the old iron bearing one also.
